Date/Time: Fri, 22 Nov 2024 07:03:50 +0000
Edit Global Symbol Settings Causing Freeze
View Count: 1594
[2013-05-10 16:51:25] |
tyler - Posts: 14 |
Hey guys, Not sure if this is global, but on my system when I go into any of my detached charts, press F5 and then select "Edit Global Symbol Settings" the main screen, the one that displays the connection and would display spreadsheets, freezes. All detached charts continue to operate perfectly, orders go through, etc. But the main hub becomes unusable. Also, the global symbol settings screen never opens, no matter how long I wait. |
[2013-05-10 21:55:28] |
This generally relates to a problem in the operating system not having enough memory/resources to display the Global Symbol Settings windows. We will see what can be done in the next release to work around this. When this happens simply press the Escape key. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-11 09:44:40
