Date/Time: Tue, 15 Apr 2025 13:56:45 +0000
number bars calculated value volume filtering inaccuracies
View Count: 34
[2025-04-03 21:02:55] |
User887126 - Posts: 85 |
Hi SC team, on my first chart, i use volume filtering to see only volume with certain lots (> 10 lots for example). I have custom ACSIL study on this chart and they are both showing the same volume. On my second chart, i use number bars calculated volume study with same volume filtering. the number on this does not match the number from first chart. the chart refresh rate, type of chart and time interval are all the same. I also put yes on combined summary trade option. not sure what the issue is. it may be just that the screen on second chart is not refreshing at the same rate as the first chart somehow. please review and advise. Date Time Of Last Edit: 2025-04-03 21:12:16
