Date/Time: Tue, 15 Apr 2025 13:54:19 +0000
Daily Change % Alert (Avoid Limit Down)
View Count: 83
[2025-04-03 17:31:19]
User753526 - Posts: 57
I had a search on the support board but couldn't find a similar topic.
I wanted to set an alert if any instrument reached a certain percentage drop or gain from the previous days close/settlement price. This would alert me if price became within a range close to a market Price Limit before the pause the instrument.
Is there a function in Sierra Chart to set an alarm on a percentage of daily movement say 3%, 4% or 5% etc?
[2025-04-03 18:01:16]
John - SC Support - Posts: 39274
Use the "Percent Change Since Previous Close" study to get the amount of change and then setup an alert for that value. Refer to the following:
Study/Chart Alerts And Scanning
