Date/Time: Tue, 15 Apr 2025 14:31:38 +0000
New instance trading
View Count: 53
[2025-04-03 16:40:46] |
Sasikanth Peri - Posts: 6 |
Hi I've set up a new instance and in my original instance I have the denali 11 package, how do i create a new trade account say apex onto my second instance, I trade a live account on my primary instance, when i try the Data and trade services - it says read only DTC - Sub instance. My server and historical ports are different from the primary, could you please help me out
[2025-04-03 16:53:03] |
John - SC Support - Posts: 39275 |
To use a completely different trading account you need to install a second Sierra Chart. You cannot use a sub-instance (started with File >> New Instance) to do this, as these sub-instances are connected to the main instance and use the same trading account. Refer to the following to install another Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart As long as the second installation is on the same computer, and you do not have more than 3 total separate installations on the same computer, then there are not additional fees or any particular changes that you would need to make. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
