Date/Time: Tue, 15 Apr 2025 14:06:23 +0000
DOM Help
View Count: 68
[2025-04-03 15:31:18]
honkeyred77 - Posts: 2
So I have a DOM already set up in the chartbook I imported. I am trying to create a second DOM to add into the same chartbook and I cannot get the new DOM to match what the first DOM looks like. From the color schemes to the data thats coming in. I have gone through tutorials and tried using the global settings but nothings worked.
[2025-04-03 16:34:43]
John - SC Support - Posts: 39275
The best way to get the DOM the same is to duplicate the one you like and then change the symbol in the new DOM. Refer to the following:
Using Chart Templates: Duplicating Charts / Template Charts
[2025-04-03 21:22:30]
This worked John. Thank you so much.
