Date/Time: Tue, 15 Apr 2025 13:59:11 +0000
Mark arrea does not work on the chart
View Count: 38
[2025-04-03 14:18:30] |
Stefan Alexandru Ilie - Posts: 2 |
Hello, i am using "copy chart drawings" and it does not work on all charts. Could you please check why ? Please see screenshot below. Kind regards, Alex |
[2025-04-03 14:20:51] |
John - SC Support - Posts: 39274 |
Copying drawings from a TPO chart can be difficult, as the concept of bars and their times is not straightforward. But, since this drawing covers most of the TPO period, it should show on another chart covering most of that day. What we see from your image is that the drawing is done on Monday March 31, 2025, but the display of the bars in the chart that you state it is not showing are for April 2, 2025. Scroll back the chart to Monday March 31 and see if you are able to see the drawing there. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
