Date/Time: Wed, 23 Apr 2025 18:00:46 +0000
surface of Tool Configs changed
View Count: 63
[2025-04-03 13:58:11]
El Li - Posts: 1
resently the Tool Configs e.g. for "Retracement" has changed. It looks black with many rows, like in Globals Settings > General settings
Before it looked like in your documentation
Chart Drawing Tools: Using Multiple Drawing Tool Configurations
I can hardly chance the settings of my tool, so I want to ask if this is normal?
Or do you have changed the surface of the tool configs?
[2025-04-03 14:10:14]
John - SC Support - Posts: 39436
This change is correct. It is part of the move to get rid of the old windows and implement our new ones that are not tied to Microsoft.
The functionality is the same, it is just the particulars of how you access and change an item on the window. Refer to the following for a primer on how these new windows work:
Settings Windows Interface
