Date/Time: Tue, 15 Apr 2025 14:29:11 +0000
Show Order Fills (not working anymore)
View Count: 84
[2025-04-03 12:07:45]
User135243 - Posts: 66
Since some days, I guess since SC 2747 or SC 2749 if I check under Trade: Show Order Fills it doesn't appear anymore, it worked fine in the past. Is it possible that the updates change the settings?
[2025-04-03 14:07:41]
John - SC Support - Posts: 39275
Refer to the following for all the information on things to check regarding showing Order Fills:
Chart Trading and the Chart DOM: Displaying Order Fills on the Chart
[2025-04-03 14:19:08]
Yes, as said Show Order Fills is checked, but it doesn't work anymore, it worked for the last month and I've not changed anything
Date Time Of Last Edit: 2025-04-03 14:19:46
[2025-04-03 15:07:31]
There is more than just "Show Order Fills" called out in that section. Other items like ensuring you have the correct account selected, and how the Order Fills Start Date-Time is set. Please make sure you go through all of the items in the link give previously to ensure everything is set correctly.
[2025-04-03 19:28:20]
Hi John, thank you very much, now with this instructions (keyword: account) I could find the problem, I switched the account some days ago, that's why I couldn't see the fills on chart :) and by selecting: Trade >> Open Trade Window for Chart
here I could solve it (there was the old account set)
