Date/Time: Tue, 15 Apr 2025 14:27:25 +0000
Sierra Chart - Chart trade values / parameters display
View Count: 41
[2025-04-03 10:36:22] |
stefkovic.m28 - Posts: 31 |
Hello, is it possible in Sierra to display this axis values always with visual offset from the right side? I need to see the candles and also name of parameters on the right side of chart. See my screen for clarification. thanks |
[2025-04-03 13:57:34] |
John - SC Support - Posts: 39275 |
Refer to the following: Chart Menu: Lock Fill Space (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
