Date/Time: Tue, 15 Apr 2025 14:11:17 +0000
Current Bid Ask Lines Study and Trade and Current Quote Symbol
View Count: 55
[2025-04-03 08:41:46] |
User240337 - Posts: 9 |
Does the Current Bid Ask Lines Study reflect Trade and Current Quote Symbol? Example. Chart Symbol is set as CL Trade and Current Quote Symbol is set to MCL Will the Current Bid Ask Lines Study reflect MCL? Thank you |
[2025-04-03 13:49:29] |
John - SC Support - Posts: 39275 |
It depends on the setting for "Use as Trade Only Symbol". Refer to the following: Chart Settings: Use as Trade Only Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
