Date/Time: Tue, 15 Apr 2025 14:27:26 +0000
I WANT TO KNOW WHAT PACK TO GET TO CONNECT WITH TOPSTEP WITH SIERRA CHART
View Count: 61
[2025-04-03 07:25:44]
UserARTUR - Posts: 2
I HAVE BEEN LEARNING HOW TO USE SIERRA CHART FOR PAST FEW MONTHS IM TRYING TO USE TOPSTEP WITH SIERRA CHART AND I WANT TO KNOW THAT WHICH PACKAGE DO I NEED TO GET LIVE DATA AND USE ALL TOOLS LIKE VWAP , MARKET PROFILE , CUMULATIVE DELTA , FOOTPRINT ETC ! I WANT TO KEEP THE COST AS LOW AS POSSIBLE AS IM A STUDENT AND NEED WAYS TO KEEP THE COST LOW HOPEFULLY YOU GUYS COULD HELP ME OUT WITH A EASY AND LOW COST APPROACH I WAS TOLD TO GET THE SERVICE PACK 11 BUT DO I ALSO HAVE TO GET THE DATA OR NOT ? IM NEW TO THIS PLEASE HELP ME WITH THE ENTIRE PROCESS WOULD REALLY APPRECIATE THANKS!! AS I HEARD THAT TOPSTEP PROVIDE DATA IM NOT SURE IF THAT SUFFICIENT I BELIEVE A LOT OF PEOPLE ALREADY ASKED ABOUT IT SO YOU GUESS COULD GUIDE ME THANKS IN ADVANCE !!! CHEERS!!
Date Time Of Last Edit: 2025-04-03 07:33:31
[2025-04-03 13:47:45]
John - SC Support - Posts: 39275
For the items you state you want, your lowest cost option is the "Integrated Advanced" package (package 11). The cost is $46.00 per month, although there are multiple month discounts available. Refer to the information for the packages at the following link:
Description of Service Packages and Pricing
As to the data, you can get the CME Group data from Rithmic, which is the trading service that Topstep uses. Just be aware that there is a lack of historical data available from Rithmic, so if you depend on longer term charts (more than 5 days of data), then you will probably not get what you need from Rithmic. Refer to the information at the following link:
Rithmic Trading Platform Service: Rithmic Support Policy
Should you decide you would rather get your data from us, then you need to understand the CME Group requirement that you have a live, funded, futures trading account in order to get the data at the non-professional rates. Refer to the following:
Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
Then to setup the data, follow these instructions:
