Date/Time: Tue, 15 Apr 2025 14:08:51 +0000
Frozen chart during Chart replay
View Count: 55
[2025-04-03 06:12:43]
User358514 - Posts: 11
Hey!
I would like to backtest my strategies, but when I use the Chart replay functionality and I try to change the barperiod/timeframe, sometimes(1 of 10) one of the chart freezes.
In my case it keeps showing the "Loading" state until I exit from Chart replay.
This state does not have unusually high CPU or memory usage, so I assume it does not load endless amount of data.
imageScreenshot from 2025-04-03 07-55-14.png / V - Attached On 2025-04-03 06:12:06 UTC - Size: 105.66 KB - 13 views
[2025-04-03 08:10:19]
Sierra_Chart Engineering - Posts: 19226
Very hard to say what the problem is. And when you are using Wine, it adds further complications. Not sure how we can help with this.
[2025-04-03 09:20:35]
Alright, trying to find other way.
Is it possible to start/pause chart replay by a study or any API-like connection?
[2025-04-03 13:53:39]
John - SC Support - Posts: 39275
Yes, this is available through a Custom Study. Refer to the following:
ACSIL Interface Members - Functions: sc.PauseChartReplay()
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
