Date/Time: Mon, 28 Sep 2026 18:17:25 +0000
spreadsheet study question about using value as reference
View Count: 540
[2025-04-03 05:04:07]
User488241 - Posts: 44
If I calculate a integer numerical value, is there a way I can reference that cell as the range amount for another cell?
For instance, I calculate the integer 5 in cell k3.
I want to use the following expression min(e3:e(k3))
How would I go about accomplishing this?
Thank you!
[2025-04-03 05:51:58]
Sierra_Chart Engineering - Posts: 24994
We have to look into this. Should not be difficult if we do not have this already to create a function that can return a range reference based upon, all integer values. Top left row column, bottom right row column.
Date Time Of Last Edit: 2025-04-03 05:52:22
[2025-04-03 13:25:42]
Sawtooth - Posts: 4355
This should work:
=MIN(E3:OFFSET(E3,K3-3,0))
Or this, if K3 is absolute:
=MIN(E3:OFFSET(E3,K$3-3,0))
