Date/Time: Tue, 15 Apr 2025 14:04:00 +0000
Custom Studies Control Panel: Remove Study
View Count: 77
[2025-04-02 22:59:27]
Gradient - Posts: 118
How can a custom study be removed from the Control Panel?
I see options to add but not one to remove.
Thanks.
[2025-04-03 03:40:28]
Sierra_Chart Engineering - Posts: 19226
There definitely should be a way to do this. We are checking on this.
[2025-04-03 15:52:56]
User584084 - Posts: 283
1) Open the Add Custom Study Window in SierraChart. Get the custom study .dll name in parentheses for the custom study you wish to remove.
2) Open Windows Explorer
3) Go to the SierraChart >> Data directory
4) Search for the custom study .dll name from step 1.
5) Before removing the dll, copy the dll to another location. You will have a backup of the dll should you need it.
6) If the dll contains more than 1 custom study in the control panel, it is not possible to remove/delete only 1 custom study from the dll. All the custom studies will be removed when the dll is removed.
7) If the dll contains just 1 custom study, then you can remove/delete the dll and it will remove the custom study from the control panel.
Date Time Of Last Edit: 2025-04-03 15:54:32
