Date/Time: Tue, 15 Apr 2025 14:29:11 +0000
Level 2 date with denali
View Count: 44
[2025-04-02 20:40:55] |
aurel19230 - Posts: 4 |
Hello, I’ve read through the documentation thoroughly but couldn’t find an answer to my question. I’ve had DOM Level 2 data with Denali for 7 months now (for example, ESM5.CME.2024-09-15). However, I can only load Level 2 data in the replay starting from early October. Even with the files downloaded locally, the replay only allows access to 6 months of historical data. Is it possible to use the Level 2 replay for more than 6 months of history? Thank you for your support. |
[2025-04-02 21:18:45] |
John - SC Support - Posts: 39275 |
Check this setting and see that it is set high enough for how much data you are wanting to load: Chart Settings: Maximum Market Depth Data Days to Load (Chart >> Chart Settings >> Market Depth menu) Also, we are wondering if this is a Continuous Futures chart or not. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
