Date/Time: Tue, 15 Apr 2025 13:52:34 +0000
Detached hidden windows
View Count: 109
[2025-04-01 14:58:07]
Jimmyy - Posts: 266
Is it possible to not restore detached hidden windows upon restoring the main window?
I am aware of the setting Minimize/restore detached windows with main window and i have set it to yes because i do need other detached windows to be restored. Just dont want the hidden detached windows to restore
[2025-04-01 16:57:18]
John - SC Support - Posts: 39274
We just tried this to ensure how it works, and what occurs for us is that hidden detached windows are NOT restoring with the main window, regardless of the setting for "Minimize/Restore Detached Windows with Main Window".
So this should be working the way you are expecting and we do not know why would not be.
[2025-04-02 13:11:59]
Jimmyy - Posts: 266
The setting "Minimize/Restore Detached Windows with Main Window" has to be set to yes because like i said i do need other detached windows to be restored. and if the setting is set to no : only the main the window minimizes and restores and nothing happens to the detached windows.
the attached hidden window in my main window does not restore upon restoring the main window, but the detached hidden windows do restore upon restoring the main window. do you want me to make a screen recording and send it ?
[2025-04-02 15:47:00]
Please get us your chartbook and we'll see if we can reproduce it. Follow these instructions to get us the Chartbook:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2025-04-03 15:24:20]
Jimmyy - Posts: 266
Hi, so i think the problem happens if that detached hidden window is on another monitor.
So, I tried to make a new chartbook with two charts one attached and one detached hidden window, if the detached hidden window is on the same monitor as the main window then upon restoring - the detached hidden window restores for a quick second along with the main window and minimizes instantly. idk if that is normal behavior.
whereas if that detached hidden window is on another monitor, then it just restores along with the main window. Attaching the chartbook where the detached hidden window is on another monitor.
Date Time Of Last Edit: 2025-04-03 15:25:24
Private File
[2025-04-03 21:40:19]
Sierra_Chart Engineering - Posts: 19226
We know why there is a problem. We will resolve this in the next release.
