Date/Time: Tue, 15 Apr 2025 14:04:00 +0000
how to code or fulfill criteria
View Count: 49
[2025-03-31 16:56:15]
lservin29 - Posts: 67
based on MARKET DEPTH HISTORICAL GRAPH study,
if LN:22 (desired outcome to draw yellow horizontal line) and LN:19 (desired outcome blue horizontal line) trigger a color fulfillment in the heatmap then draw a horizontal line.
would this require LN:34 and would it require a color based on alert condition alert or would this require a spreadsheet?
what is simplest way to achieve this?
imageHEATMAP alert.jpg / V - Attached On 2025-03-31 16:56:04 UTC - Size: 186.89 KB - 17 views
[2025-03-31 19:22:39]
John - SC Support - Posts: 39274
There is not a way to do this using the built-in tools, as the Market Depth data is not accessible data within the program. You would need to create a custom study to do what you want. Refer to the following:
ACSIL Interface Members - Historical Market Depth Data (c_ACSILDepthBars)
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
