Date/Time: Tue, 15 Apr 2025 13:50:09 +0000
[Programming Help] - Custom Quote/Values Window
View Count: 53
[2025-03-31 03:22:28] |
User303857 - Posts: 131 |
Hello Support Board I have been making use of the text display for study and putting the results right on the chart. And want to make use of more of them with different adjustments. Is there a way to have a custom quote window or chart values window loaded with theses values? And, display them visible/not visible with a control bar button? Some kind of matrix 4 columns 12 rows? Or is this where the spreadsheet should be used? |
[2025-03-31 14:01:37] |
Sierra_Chart Engineering - Posts: 19226 |
Have a look at the Study Summary window: Study Summary Window Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-04-02 00:08:13] |
So, is there a way for it to show the values for Text Display for Study or Text Display For Study from Chart? They are not visible in the study summary field selection choices. They are visible on the chart but not in the summary window. I JUST CHANGED the DRAW style for a price overlay study that is being used for the cumulative volume to anything except text, line , bar , right arrow, value on high. And, now the field populates with the correct number. And it works with the study hidden. When using the text draw style it is blank in the Study Summary window. Why does the text setting not work but all of the other draw styles work? Thanks Date Time Of Last Edit: 2025-04-02 00:35:32
[2025-04-02 15:17:51] |
John - SC Support - Posts: 39274 |
What you are stating should not be the case, at least not for a Study/Price Overlay of a Cumulative Volume. As long as the Subgraph itself for the study has valid information in it (i.e. it is non-zero) then it should show properly in the Study Summary. So we are not fully understanding why you would see anything different. Items like the "Text Display for Study" are different, as the Subgraph doesn't contain any information, it is just to set colors. The actual item on the chart is a drawing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
