Date/Time: Mon, 30 Nov 2026 11:34:46 +0000
market depth data
View Count: 1232
| [2014-09-26 07:48:06] |
| User25540 - Posts: 22 |
Hello, Can I establish a link between market depth data and spreadsheet? If no, do you consider to develop the functionality? |
| [2014-09-26 08:02:40] |
Yes, this can be done. Add the Depth of Market Data study to the chart.
