Date/Time: Tue, 15 Apr 2025 13:44:49 +0000
Volume traded in the last 60 seconds
View Count: 97
[2025-03-30 18:30:54]
ATEX - Posts: 25
Is there any indicator or way to sum the volume traded in the last 60 seconds?
Best regards,
A
[2025-03-30 20:26:41]
Sierra_Chart Engineering - Posts: 19226
Yes. Use the Volume study:
Volume
And set the chart bars to 1 minute per bar:
Changing Chart Bars Period
[2025-03-30 21:03:58]
ATEX - Posts: 25
Thank you for your reply.
I believe the solution you are suggesting will only be correct for the current moment once per minute - when the bar calculation is complete.
Ideally I would like something that continuously sums up the volume for the past 60 seconds (or n periods), and that is also compatible with any chart bar period.
I suspect I will have to write this myself.
Best,
A
Date Time Of Last Edit: 2025-03-30 21:06:40
[2025-03-30 21:29:48]
This can be done with the Volume by Price study:
Volume By Price Study: Volume Graph Period Type
Use this Volume Graph Period Type:
Volume By Price Study: One Period at End of Fixed Time Length
