Date/Time: Thu, 24 Sep 2026 14:31:03 +0000
Cannot get this small program to compile.
View Count: 642
| [2025-03-28 21:08:00] |
| User216417 - Posts: 1 |
Hi Sierra Chart Support, I'm using version 2747 and attempting to build a custom study that accesses stochastic values from another study using: SCFloatArrayRef KArray = sc.Subgraph[0].Data; SCFloatArrayRef DArray = sc.Subgraph[1].Data; sc.GetStudyArrayUsingIDFromChartIDStudyID(sc.ChartNumber, StochasticStudyID.GetInt(), 0, KArray); sc.GetStudyArrayUsingIDFromChartIDStudyID(sc.ChartNumber, StochasticStudyID.GetInt(), 1, DArray); However, the remote build consistently fails with the following error: error: invalid initialization of non-const reference of type 'SCFloatArrayRef' from an rvalue of type 'int' I’ve ensured: I'm using SCFloatArrayRef from sc.Subgraph[x].Data min and max macros are properly undefined No incorrect type assignments or parameter mismatches Is there something in version 2747 or the remote build server that may cause this behavior? I’d appreciate your guidance on what’s going wrong. Thank you! |
| Attachment Deleted. |
| [2025-03-28 21:48:30] |
| User719512 - Posts: 480 |
Have you seen: ACSIL Interface Members - Functions: sc.GetStudyArrayFromChartUsingID() |
