Date/Time: Tue, 15 Apr 2025 13:47:44 +0000
[User Discussion] - Spreadsheet exit fails on replay
View Count: 86
[2025-03-28 19:48:08]
Leif - Posts: 14
During replay when the column for Buy or Sell Exit formula generates a "1" the order still fails to close. I checked all the spreadsheet settings and they seem correct to me. The service log states "the exit (sell) signal ignored because the Current Alert Condition Formula is TRUE" What am I missing here? Thanks
[2025-03-29 13:34:29]
Sawtooth - Posts: 4201
A signal only occurs when the condition goes from FALSE to TRUE (0 to 1).
Subsequent signals require a reversion to FALSE before another signal can occur.
[2025-03-29 18:11:04]
Leif - Posts: 14
Thanks for the reply. However the exit column does mostly have 0’s before 1 occurs. I just can’t figure out when it turns TRUE why the order doesn’t close.
[2025-03-29 22:36:25]
You might want to set 'Reset Condition on New Bar' to Yes.
Date Time Of Last Edit: 2025-03-29 22:48:03
[2025-03-30 19:09:05]
Leif - Posts: 14
Thanks for the suggestion but it is “yes” for reset alert condition on new bar”. All settings seem correct to me.
