Date/Time: Tue, 15 Apr 2025 13:50:09 +0000
custom symbol
View Count: 74
[2025-03-28 17:26:03] |
lservin29 - Posts: 67 |
hello, first let me say that I have used custom symbol several times and never had issues. i know how to set up my T10 or Mag7 symbol. I am updating the percentages and the following equation would not work BUT when I removed BRK.B-NQTV from the equation it worked just fine. please help understand why BRK.B-NQTV wont work....also I use it as a symbol by itself and it works and loads fine. 0.195664414*{AAPL-NQTV}+0.158783784*{NVDA-NQTV}+0.168918919*{MSFT-NQTV}+0.110641892*{AMZN-NQTV}+0.076858108*{META-NQTV}+0.100225225*{GOOGL-NQTV}+0.044481982*{TSLA-NQTV}+0.047015766*{AVGO-NQTV}+0.040259009*{JPM-NQTV}+0.057150901*{BRK.B-NQTV} |
[2025-03-31 14:16:07] |
Sierra_Chart Engineering - Posts: 19226 |
We will check on this.
[2025-03-31 19:22:09] |
Jeffrey - Posts: 2245 |
The length of that symbol is likely too long to be stored as a file in your data files folder. You could possibly try shortening it by removing some of the decimal precision on some of those numbers. At least until a better solution becomes available.
