Date/Time: Fri, 18 Apr 2025 06:23:46 +0000
[User Discussion] - Stochastic Momentum Index Ergodic Rate of Change
View Count: 92
[2025-03-28 16:56:14] |
User149333 - Posts: 23 |
Is it possible to create something close to this using the standard indicators (I'm not that technical) in SC? It is essentially Linda Raschke’s SMI Ergodic ROC (Stochastic Momentum Index Ergodic Rate of Change), a refined momentum oscillator that combines elements of the Stochastic Momentum Index (SMI), Ergodic smoothing, and Rate of Change (ROC). I can see the Ergodic & the Stochastic Momentum Indicator studies, but the settings don't relate. SMI Ergodic ROC Formula & Construction (attached) Or see url: https://app.screencast.com/lMKJlHvOSS156 Many thanks |
