Date/Time: Fri, 18 Apr 2025 06:40:12 +0000
[Programming Help] - Issue with Session Reset Logic in Custom ACSIL Code
View Count: 97
[2025-03-28 15:06:28] |
__Kai__ - Posts: 15 |
Dear Sierra Chart Support, I am encountering an issue with my ACSIL code that is designed to detect session changes or the start of RTH at 9:30, and then calculate a 'lookback' variable representing the number of bars since the reset. However, the reset is unexpectedly triggered every 2-5 bars instead of only at the intended session start or RTH time. Below is a snippet of my code: int lookback = cumulative_SMA_lookback; if (SessionBreakType == 1) { static int sessionStartIndex = 0; static SCDateTime lastSessionDate; // Last date when the reset was executed // Determine the start time of the current trading day SCDateTime currentDayStart = sc.GetTradingDayStartDateTimeOfBar(sc.BaseDateTimeIn[sc.Index]); // Compare with the start time of the previous bar (if available) SCDateTime previousDayStart = (sc.Index > 0) ? sc.GetTradingDayStartDateTimeOfBar(sc.BaseDateTimeIn[sc.Index - 1]) : currentDayStart; // If it is the first bar or the trading day start changes // and no reset has yet been executed for this trading day if ((sc.Index == 0 || currentDayStart != previousDayStart) && currentDayStart != lastSessionDate) { sessionStartIndex = sc.Index; lastSessionDate = currentDayStart; } lookback = sc.Index - sessionStartIndex + 1; } else if (SessionBreakType == 2) { static int rthStartIndex = 0; static SCDateTime lastRTHDate; // Date when the reset was last executed SCDateTime currentBarDate = sc.BaseDateTimeIn[sc.Index].GetDate(); SCDateTime rthStartTime = currentBarDate; rthStartTime.SetTimeHMS(9, 30, 0); // Reset only if no reset has been executed for this day // AND the current bar is >= 9:30 and the previous bar was before 9:30 if (currentBarDate != lastRTHDate && sc.BaseDateTimeIn[sc.Index] >= rthStartTime && (sc.Index == 0 || sc.BaseDateTimeIn[sc.Index - 1] < rthStartTime)) { rthStartIndex = sc.Index; lastRTHDate = currentBarDate; } // Calculate the lookback from the last RTH start index lookback = sc.Index - rthStartIndex + 1; } Additionally, I have observed that when I manually trigger a Recalculate event, the code appears to work correctly for a few additional candles, but then the issue reoccurs with the reset being triggered every few bars. Could you please advise what might be causing these intermittent resets? Is there a potential issue with handling session boundaries or bar index management that I might be overlooking? Any guidance or known issues regarding this behavior in ACSIL would be greatly appreciated. Thank you for your assistance. Greetings Kai |
[2025-03-28 16:41:22] |
JohnR - User831573 - Posts: 330 |
I don't have a specific answer for you, but you may want to try to step through the code with the VS2022 debugger. I have not used these functions, but the docs say SCDateTime currentDayStart = sc.GetTradingDayStartDateTimeOfBar(sc.BaseDateTimeIn[sc.Index]); Typically this will be the Date-Time of a bar. -- notice the word BAR in the function. You might want to change to this function. sc.GetSessionTimesFromChart() int GetSessionTimesFromChart(const int ChartNumber, n_ACSIL::s_ChartSessionTimes& r_ChartSessionTimes); The sc.GetSessionTimesFromChart() function sets the chart session times in r_ChartSessionTimes for the chart defined by ChartNumber. r_ChartSessionTimes: A s_ChartSessionTimes structure that contains the session times for the given chart. The s_ChartSessionTimes members are the following: SCDateTime StartTime SCDateTime EndTime SCDateTime EveningStartTime SCDateTime EveningEndTime int UseEveningSessionTimes int NewBarAtSessionStart int LoadWeekendDataSetting JohnR |
