Date/Time: Tue, 15 Apr 2025 13:43:34 +0000
Chart Linking
View Count: 106
[2025-03-27 22:15:57]
User535599 - Posts: 13
Where can I set this Chart Linking?
imageChart Linking.png / V - Attached On 2025-03-27 22:15:33 UTC - Size: 68.34 KB - 28 views
[2025-03-31 14:11:56]
Sierra_Chart Engineering - Posts: 19226
Is this for a Quote Board?
[2025-03-31 17:36:56]
When I click on Chart Header Link Number this Linking panel pops up. Where can turn it on, off?
image_Chart Linking_.png / V - Attached On 2025-03-31 17:36:41 UTC - Size: 61.14 KB - 12 views
[2025-04-01 08:21:33]
You need to remove the Link Number field from the Chart Header:
Working With Charts: Region Data Line / Chart Header
[2025-04-01 09:38:12]
Thank you!
If OpenGL is enabled, the Chart Linking panel will not appear.
