Date/Time: Fri, 18 Apr 2025 06:37:46 +0000
Show compact tool value windows
View Count: 76
[2025-03-27 18:19:27] |
User613910 - Posts: 50 |
Hi, My compact tool value windows only shows the price. I always saw High / Low bar etc. Suddenly this is gone why?? Problem is I can not find where to adjust this. I tried to search it in the Support with the search 'adjust compact tool values window" pretty clear but I don't get any good answer on this. So unfortunately I have to ask you and take time from your support. Why is it gone and why does it shows only price. What is the use of that?? Thanks, Anita |
[2025-03-27 18:58:45] |
John - SC Support - Posts: 39353 |
Most likely, you have the following setting set to "No": Chart Settings: Display Main Price Graph Values in Values Windows (Chart >> Chart Settings >> Display >> Chart Values menu) But, it's also possible that you have deselected all the items from being displayed in the window. Refer to the item just below the link given above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
