Date/Time: Fri, 18 Apr 2025 06:33:01 +0000
Automatic position size detection for stops
View Count: 70
[2025-03-27 17:57:06]
User224223 - Posts: 3
Hi all,
Tried looking for answers to this but can't seem to find any.
I use preset templates for attached orders (particularly stops) and send them after I build my position using "send attached orders by position". The templates need you to define the stop quantities in advance. My sizing varies and so I end up having to modify the quantities after sending the order. Is there a way to have SC use the current open position size for the attached orders?
Hope I explained that clearly.
Thanks.
[2025-03-27 18:15:16]
John - SC Support - Posts: 39353
There is not a built-in way to do this. You would have to create a custom study to do what you want. Refer to the following:
Automated Trading From an Advanced Custom Study
https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php
