Date/Time: Fri, 18 Apr 2025 06:28:17 +0000
My H4 chart scales changed to daily
View Count: 81
[2025-03-27 17:36:21]
User613910 - Posts: 50
My H4 (240 min) time scale changed to daily and I can not find where to reset this. I want to see every H4 bar time not only the daily. tried to find this with the search engine but no succes after multiple different entries.
Also see attached my screenshot. (sorry I am in a sort of Murphy's law here because I also asked you about the Tools value windows. Probably clicked on something while I was looking for that problem.
Already thanks,
Anita
imageH4 horizontal.GIF / V - Attached On 2025-03-27 17:34:47 UTC - Size: 240.02 KB - 19 views
[2025-03-27 17:44:40]
John - SC Support - Posts: 39353
Refer to the following:
Changing Chart Bars Period
[2025-03-27 17:51:08]
Don't understand your answer. I have a H4 chart with a daily time. I don't see the time values of the different H4 bars only the day value....... I know how to change bar periods.... (I work with sierra almost 10 years).
Anita
[2025-03-27 18:09:36]
It is only showing the days due to the closeness of the bars. If you expand your chart out you will see the individual times for the bars.
[2025-03-27 19:17:35]
I made a change in Tool Settings while looking for the 'çompact tools values' and accidently changed Show Value and Time Boxes....!!
Thanks for support
