Date/Time: Fri, 18 Apr 2025 06:23:45 +0000
Candlestick Colors - Wick and Body Mismatch
View Count: 57
[2025-03-27 16:40:57]
User377189 - Posts: 215
For your review, I have attached a screenshot highlighting an issue where some candlestick bars display mismatched colors between the body and the wick. Specifically, red candlesticks have green wicks and vice versa. Please advise on a resolution.
Private File
[2025-03-27 16:49:09]
John - SC Support - Posts: 39353
You have a study that is changing the colors, or your graphics settings are setup to be those colors. You need to check into both of these to see what is causing this.
For studies, remove the studies one-by-one to see if one of them affects the bars. When it changes, then the last study removed was the culprit.
For the graphics, settings, refer to the following and the three items below it:
Graphics Settings: Candlestick Up Outline
Also take a look at the following setting to see if you made a change to this:
Graphics Settings: Color Candlestick High-Low Using the Outline Colors (Global Settings >> Graphics Settings >> Other)
