Date/Time: Fri, 18 Apr 2025 06:33:01 +0000
cme futures
View Count: 212
[2025-03-27 15:41:52]
User103472 - Posts: 10
Hi
I have an account with apex and rithmic
I also pay $25 for a level 3 service
Can you tell me if I am entitles to real time futures data as when I connect to ESM25-CME and NQM25-CME my data is delayed by 10 minutes
if not can I change it to the package that allows me a rithmic feed please
thankyou
[2025-03-27 16:09:40]
John - SC Support - Posts: 39353
You need to be on one of the "Integrated" packages in order to have access to real-time data and trading services. You cannot do this on the "Base" packages - you are on the "Base Standard" package. Refer to the information for the packages at the following link:
Description of Service Packages and Pricing: Packages
If you want to change your package, follow these instructions:
Sierra Chart Purchase and License Information: Changing Package
After you change your package, you can connect to Rithmic by following these instructions:
Rithmic Trading Platform Service: Setup Instructions
You can get your data either from Rithmic or from our Denali Exchange Data Feed. If you want to get the data from us, then you need to understand the CME Group requirement that you have a live, funded, futures trading account in order to get the non-professional data. Refer to the following:
Denali Exchange Data Feed: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
[2025-03-27 18:23:00]
Hi John
Thanks for your quick reply I appear to be connected to rithmic now. I have connected to NQm5.cme and ESM5.cme but I cannot find the symbols for dow us30, gold and usoil
can you help
[2025-03-27 19:08:41]
Are you looking or the DOW, US30, Gold, and USOil CFD data? Or are you looking for the Futures data from the CME Group?
[2025-03-28 09:50:24]
futures data from the cme group
[2025-03-28 10:03:14]
User135243 - Posts: 66
Dow = YMM5 Crude oil = CLK5 Gold = GCM5 (maybe why you cannot find the symbols is, because you're using CFD terms :) )
[2025-03-28 13:41:03]
I can get ESM5.CME and NQM5.CME to work but it only works with the CME extension
I cannot get dow or oil or gold to work
[2025-03-28 14:19:29]
Those are traded on different exchanges - not the CME exchange - for instance, Gold is traded on the COMEX exchange.
To get the correct symbols for the service you are using you need to use the "File >> Find Symbol" window and open the particular exchange you need for that product. You can also search for a product on that window. Refer to the following:
File Menu: Find Symbol (File)
[2025-03-28 16:01:47]
I have found that it uses the comex codes and not the monthly codes so does that mean this is a continious contract rather than having to rollover every 3 months?
I found that these worked when I changed to SC data and then back to rithmic
steve
[2025-03-28 17:05:00]
the 3 month rollover is for equity- and fx-futures, Gold rolls each 2 month, Crude rolls each month
[2025-03-28 19:39:34]
What is the symbol you are seeing/using?
Keep in mind that every service uses a different symbology - so the symbols that you would use for Rithmic, are not going to work for "SC Data" and vice versa.
