Date/Time: Tue, 15 Apr 2025 14:18:50 +0000
[User Discussion] - AHK version 1.1.37.02
View Count: 135
[2025-03-26 18:38:46] |
User14953 - Posts: 248 |
AHK version 1.1.37.02 Looking to create a *.ahk file to Clear the Alert Manager Log. |
[2025-03-27 20:43:44] |
JohnR - User831573 - Posts: 330 |
Here is one way of doing it. 1 - I tied it to the Alt left mouse button. Change it to what ever you prefer. 2 - You can call it what ever you want or add it to your existing AHK file 3 - I put in a Sleep for 1 sec between each step so you can see what it is doing. Change it to as fast as your system can handle if you choose to. All sleep times do not have to be the same duration. I usually use 100 - 250 depending on what I am trying to do. 4 - You can eliminate the last step(s) which responds to SCs popup to confirm delete. 5 - I did not try to eliminate the lines above the ! left mouse macro. I needed them for another thing I use AHK for. Hope this helps JohnR ; #NoEnv ; Recommended for performance and compatibility with future AutoHotkey releases. ; #Warn ; Enable warnings to assist with detecting common errors. ; SendMode "Input" ; Recommended for new scripts due to its superior speed and reliability. ; SetWorkingDir (%A_ScriptDir% ) ; Ensures a consistent starting directory. SetTitleMatchMode 2 SetTitleMatchMode ("Slow") DetectHiddenWindows 1 DetectHiddenText 1 ; ; ; ; ; Alt=! + Mouse Left Button = open Alert manager !LButton:: { SendInput "^!a" Sleep 1000 ; I use a sleep after each send to give the system time to "do" what I asked. You can adjust each one or take them out SendInput "!f" Sleep 1000 SendInput "{Right 4}" Sleep 1000 SendInput "{Enter}" Sleep 1000 SendInput "!e" Sleep 1000 SendInput "{Down 6}" Sleep 1000 SendInput "{Enter}" Sleep 1000 ; Lines below are for AHK to respond to confirmation request from SC to do the delete SendInput "{Enter}" Sleep 1000 SoundBeep 2550,225 ; I like to hear a sound when the macro is finished Return } ; ; Date Time Of Last Edit: 2025-03-27 20:45:24
[2025-03-28 17:40:17] |
Also, I am on AHK ver 2.0.19 not the Ver 1 JohnR |
[2025-03-29 16:31:56] |
Thanks JohnR.
Date Time Of Last Edit: 2025-03-29 16:32:15
