Date/Time: Fri, 18 Apr 2025 06:23:46 +0000
+DI and -DI lines on the ADX chart
View Count: 54
[2025-03-26 17:49:58]
User42810 - Posts: 2
Hi.
Is it possible to have +DI and -DI lines on the ADX chart in Sierra Charts? I only get the option for the ADX line itself.
Thanks.
[2025-03-26 20:56:37]
John - SC Support - Posts: 39353
You can use the "Direction Movement Index" study to get those lines. Refer to the following:
Directional Movement Index
