Date/Time: Fri, 18 Apr 2025 06:37:46 +0000
Enter trade using E-minis, but scale out using micros
View Count: 148
[2025-03-26 17:44:32]
tommartin321 - Posts: 76
I'm familiar with how to setup charting for the E-mini while executant trades on the micros.
But, what I'm looking to do is execute E-mini trades while scaling out using micros. Is this possible?
Thanks,
Tom
[2025-03-26 20:52:39]
John - SC Support - Posts: 39353
We are not understanding what exactly you want to do.
It sounds like you just want to setup the opposite situation, where the main symbol is the Micro and the Trade and Current Quote Symbol is the E-Mini.
[2025-03-26 21:01:59]
I should have posted an example.
I’d like to open a trade with 2 e-mini (which would be equivalent to 20 micros). And then scale out of the trade using micros. Take 5 off, then another 5, then another 5 and then the finale 5.
Is this possible?
[2025-03-26 21:19:09]
You cannot do this as this is not something the exchanges have setup to do. You are either trading the E-Mini or the Micro. You cannot cross between them.
