Date/Time: Fri, 18 Apr 2025 06:28:17 +0000
Market Depth Window
View Count: 69
[2025-03-26 17:11:33] |
User862138 - Posts: 25 |
Is there a method of highlighting volume, over a certain quantity or %, in both the Bid and Ask Qty or the Bid and Ask Order? That is now in the Market Depth Window. Thanks. |
[2025-03-26 20:50:37] |
John - SC Support - Posts: 39353 |
In the Market Depth Window there is no support for this. You would have to use the "Market Depth Historical Graph" and view the "Last Data" in order to get what you are looking for. Refer to the following: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#Market_Depth_Historical_Graph For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
