Date/Time: Fri, 18 Apr 2025 06:35:24 +0000
Changing a studies parameters across multiple charts
View Count: 68
[2025-03-26 12:59:54]
cmack1011 - Posts: 89
Is there a way to change a studies subgraph inputs and have those changes display across multiple charts? For example, if I have the "Horizontal Lines" study on various charts and I want to change the values of the lines on the study (Support and Resistance Lines per se), is there a way to input those values once and have the changes/values display on all the charts instead of having to go into each chart to change the values on the study within each chart?
[2025-03-26 14:41:42]
John - SC Support - Posts: 39353
The only option for this is by Linking studies. But doing so affects all the studies, meaning you have to have the same studies on all the charts with all the same settings. Refer to the following:
Chart Settings: Chart Linking >> Studies (Chart >> Chart Settings >> Linking menu)
