Date/Time: Fri, 18 Apr 2025 06:33:01 +0000
VbP Negative Delta POC
View Count: 50
[2025-03-25 18:36:12] |
User649881 - Posts: 6 |
Greetings, This is regarding the VbP drawing tool's POC for the Volume Bar Calculation Method (In:48): Ask Volume - Bid Volume. I noticed it only calculates the positive Delta, and when the Developing Point of Control (DPOC) option is enabled, we can see how all the high negative Delta is ignored. DPOC should highlight all the increases in value regardless of whether it is positive or negative. I assume an option to change negative Delta to an absolute value should do the trick. Attached is a screenshot with VbP drawing's settings below. Thank you for looking into this. Good day. In:46 = Ask Volume - Bid Volume In:48 = Ask Volume - Bid Volume In:8 = No In:49 = Difference of Bid and Ask Volume Coloring In:50 = No https://www.sierrachart.com/image.php?Image=1742927420983.png |
[2025-03-25 19:32:51] |
John - SC Support - Posts: 39353 |
This has been set as a Feature Request. We can not say when we would get to any particular request.
[2025-03-25 19:41:03] |
Thank you, John. Hoping for a sooner fix. Cheers.
