Date/Time: Fri, 18 Apr 2025 06:28:17 +0000
Not able to connect
View Count: 37
[2025-03-25 18:30:24]
ssangha84 - Posts: 128
Hello, I am not able to connect with my account for some reason. My account with Topstep is fine and I am able to log in other locations, just not Sierra Chart for some reason. Here is the log:
2025-03-25 18:25:54.229 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2025-03-25 18:25:54.229 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2025-03-25 18:25:54.229 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2025-03-25 18:25:54.363 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-03-25 18:25:54.363 | DTC Client socket (1) | New receive buffer size: 0
2025-03-25 18:25:54.363 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-03-25 18:26:14.234 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Creating socket. Using TLS 1.2.
2025-03-25 18:26:14.234 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | New receive buffer size: 0
2025-03-25 18:26:14.234 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Connecting to IP: 216.66.0.130.
2025-03-25 18:26:14.702 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 86257
2025-03-25 18:26:14.703 | Rithmic Direct - DTC | Processed connection points. Count: 369
2025-03-25 18:26:14.703 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-03-25 18:26:14.703 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-03-25 18:26:14.716 | DTC Client socket (1) | CloseSocket call.
2025-03-25 18:26:14.716 | Rithmic Direct - DTC | Disconnected.
2025-03-25 18:26:14.716 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-03-25 18:26:14.716 | DTC Client socket (1) | Closed.
2025-03-25 18:26:14.949 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | CloseSocket call.
2025-03-25 18:26:14.949 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Shutdown started. Waiting for graceful close.
2025-03-25 18:26:15.025 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Socket gracefully closed by remote side.
2025-03-25 18:26:15.025 | HTTPS connection ID:5 to downloads.rithmic.com:443 for request ID:5 (2) | Closed.
2025-03-25 18:26:18.713 |
2025-03-25 18:26:18.713 | Rithmic Direct - DTC | Using server connection: TopstepTrader-Chicago Area-Non-Aggregated
2025-03-25 18:26:18.713 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50508
2025-03-25 18:26:18.713 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50508
2025-03-25 18:26:18.714 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-03-25 18:26:18.714 | DTC Client socket (1) | New receive buffer size: 0
2025-03-25 18:26:18.714 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-03-25 18:26:38.733 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Creating socket. Using TLS 1.2.
2025-03-25 18:26:38.734 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | New receive buffer size: 0
2025-03-25 18:26:38.734 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Connecting to IP: 216.66.0.130.
2025-03-25 18:26:39.201 | Rithmic Direct - DTC | Wrote file: C:\SierraChart\RithmicConnections.json. Size: 86257
2025-03-25 18:26:39.202 | Rithmic Direct - DTC | Processed connection points. Count: 369
2025-03-25 18:26:39.202 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-03-25 18:26:39.202 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-03-25 18:26:39.223 | DTC Client socket (1) | CloseSocket call.
2025-03-25 18:26:39.223 | Rithmic Direct - DTC | Disconnected.
2025-03-25 18:26:39.223 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-03-25 18:26:39.223 | DTC Client socket (1) | Closed.
2025-03-25 18:26:39.456 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | CloseSocket call.
2025-03-25 18:26:39.456 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Shutdown started. Waiting for graceful close.
2025-03-25 18:26:39.534 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Socket gracefully closed by remote side.
2025-03-25 18:26:39.534 | HTTPS connection ID:6 to downloads.rithmic.com:443 for request ID:6 (2) | Closed.
[2025-03-25 19:00:54]
John - SC Support - Posts: 39353
Rithmic is having issues with their Chicago-area servers. Others have stated that connecting to a non-Chicago area server has worked for them (Sao Paulo in particular was mentioned as working)
