Date/Time: Fri, 18 Apr 2025 06:40:12 +0000
Ask Market Orders not displaying
View Count: 68
[2025-03-25 17:29:09] |
User106957 - Posts: 2 |
Hello, I have Chartbooks for ZB, ZN, and TN all set up identically. On ZN, the Ask-side Market Orders (MBO) are not displaying. The Bid-side are showing just fine. Both are showing just fine for ZB and TN. I've confirmed the settings for 'Symbol' are identical across all three ('0' for minimum MBO to display, so should so all that are 3 or greater). I've attached a screenshot. |
Attachment Deleted. |
[2025-03-25 18:55:15] |
John - SC Support - Posts: 39353 |
Is the displayed column the "Combined Bid/Ask Market Orders"? And what is the exact symbol for that chart? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-25 19:27:09] |
Disregard, when I went to Symbol Settings to copy the exact symbol and closed it, it appeared. Needed a refresh I guess. Thanks |
