Date/Time: Fri, 18 Apr 2025 06:25:57 +0000
Question about alert message delivery to mobile devices
View Count: 64
[2025-03-25 16:10:15]
User886314 - Posts: 18
Hi Engineer, I am having a problem with how to get the alert messages set to be delivered to my mobile device, I have read the explanation document on the official website, but I still don't understand how to realize this function, does it have to be done through telegram in order to send or receive the messages? Is it necessary to use telegram to send or receive messages? And is there a delay? Please help me to solve this problem, thanks!
[2025-03-25 17:58:50]
John - SC Support - Posts: 39353
Refer to the following and the section below it (on nfty):
Chat and Communications Platform: Using Chat for Remote Alert Notifications
[2025-03-26 03:31:38]
Hi john, I went to the link you mentioned, but the problem is still not solved, now in the ntfy application shows the problem is “login failed, the user is not authorized to access” this should be how to solve it, thank you!
[2025-03-26 13:45:47]
Most likely you did not enter the Username correctly when you were setting it up. Please go through the instructions again and be very careful with the Username that you are entering. It is best to copy/paste due to the length as noted in the instructions. Here is the link to the instructions again:
Chat and Communications Platform: Integration with Mobile Ntfy Application
