Date/Time: Fri, 18 Apr 2025 06:40:12 +0000
Rithmic connection error
View Count: 63
[2025-03-25 16:05:44]
r4ved4ve - Posts: 7
Hi!
My Sierra is having troubles connecting to the server.
Could you please help me out?
Here is the repeating cycle from the log. I will also send the full log too. Thanks!
2025-03-25 09:02:49.161 | Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated
2025-03-25 09:02:49.161 | Rithmic Direct - DTC | Trading server address/port: rsc.rithmic.com:50528
2025-03-25 09:02:49.162 | Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528
2025-03-25 09:02:49.164 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-03-25 09:02:49.164 | DTC Client socket (1) | New receive buffer size: 0
2025-03-25 09:02:49.164 | DTC Client socket (1) | Connecting to IP: 216.57.156.163.
2025-03-25 09:03:09.193 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | Creating socket. Using TLS 1.2.
2025-03-25 09:03:09.193 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | New receive buffer size: 0
2025-03-25 09:03:09.193 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | Connecting to IP: 216.66.0.130.
2025-03-25 09:03:09.924 | Rithmic Direct - DTC | Wrote file: C:\Sierra Chart\RithmicConnections.json. Size: 86257
2025-03-25 09:03:09.925 | Rithmic Direct - DTC | Processed connection points. Count: 369
2025-03-25 09:03:09.925 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window.
2025-03-25 09:03:09.925 | Select 'File >> Disconnect' to prevent further connection attempts.
2025-03-25 09:03:10.009 | DTC Client socket (1) | CloseSocket call.
2025-03-25 09:03:10.009 | Rithmic Direct - DTC | Disconnected.
2025-03-25 09:03:10.009 | Will reconnect to the server in 4.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts.
2025-03-25 09:03:10.009 | DTC Client socket (1) | Closed.
2025-03-25 09:03:10.161 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | CloseSocket call.
2025-03-25 09:03:10.161 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | Shutdown started. Waiting for graceful close.
2025-03-25 09:03:10.241 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | Socket gracefully closed by remote side.
2025-03-25 09:03:10.241 | HTTPS connection ID:12 to downloads.rithmic.com:443 for request ID:12 (2) | Closed.
[2025-03-25 17:57:22]
John - SC Support - Posts: 39353
Rithmic is having issues with their Chicago-area servers. Others have stated that connecting to a non-Chicago area server has worked for them (Sao Paulo in particular was mentioned as working)
