Date/Time: Fri, 18 Apr 2025 06:35:24 +0000
Make alert
View Count: 60
[2025-03-25 15:49:38] |
Mostafa1679 - Posts: 21 |
How I make alert enable when candle changed color and close
[2025-03-25 15:52:50] |
John - SC Support - Posts: 39353 |
There is no way to know that a bar has changed color, as that state information is not kept anywhere. The only way you would be able to do this would be to create a custom study. Refer to the following: Advanced Custom Study Interface and Language (ACSIL) https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
