Date/Time: Fri, 18 Apr 2025 06:33:00 +0000
Data Problem
View Count: 61
[2025-03-25 14:15:28] |
User839291 - Posts: 4 |
Hey There, unfortunately I got data problems again. I open my Chartbook with NQ and the data gets downloaded but stucks after the download at the point I opend it up and it can not connect somehow. I tried several times to cennct it and then it says Not Connected. Hope you can help me. Best regards, Niklas Preiser |
[2025-03-25 15:33:17] |
John - SC Support - Posts: 39353 |
Rithmic is having connectivity issues with their Chicago systems. Try changing to a different server that is not in Chicago (Sao Paulo has been suggested by others).
