Date/Time: Fri, 18 Apr 2025 06:25:57 +0000
How to hide Bid/Ask Market Depth Pulling/Stacking sum number?
View Count: 113
[2025-03-25 06:21:07] |
User492637 - Posts: 2 |
plz tell me how to do it?
Attachment Deleted. |
[2025-03-25 14:46:40] |
John - SC Support - Posts: 39353 |
There is not a way to remove those totals from the Pulling/Stacking columns. What you can do, if you do not want to see any of the totals, is change the "Chart/Trade DOM Total/Percentage Text" color to be the same as the background, then you will not see them. Refer to the following: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Total/Percentage Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-26 01:12:43] |
ty,cause the background color different,change "Chart/Trade DOM Total/Percentage Text" color to be the same as the background just hide one side
