Date/Time: Fri, 18 Apr 2025 06:33:01 +0000
Text Disappears when changing Config
View Count: 40
[2025-03-25 03:35:08] |
User915057 - Posts: 1 |
Hi There, I want to configure a few text options, only really difference being the text colour. When I type my text out and attempt to change to Config 2 for example, the Text just disappears into thin air. I've spent way too much time trying to troubleshoot this, including downloading newest version etc. reloading Sierra and still cannot solve for this. This appears to be a bug. Can you please investigate? Thx |
[2025-03-25 13:39:32] |
Sierra_Chart Engineering - Posts: 19259 |
Set Global Settings >> Tool Settings >> General >> Applying Tool Configuration to Existing Drawing Updates Text to No.
