Date/Time: Wed, 27 Nov 2024 18:36:27 +0000
Please Add Transparency Level Adjustment For Draw Styles
View Count: 1636
[2014-09-25 15:28:39]
cmet - Posts: 552
If possible, can you please add a control for transparency amount for Study Draw Styles?
Right now, the default on most colors is very dim when using dark backgrounds on charts.
Would be nice to have some kind of control over the transparency percentage (like you have in the Transparency Level in Volume By Price).
[2014-09-30 06:04:28]
This is explained in the documentation for the Subgraph Draw Styles:
http://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DrawStyle
[2014-09-30 15:16:15]
The documentation does answer the question.
Yes, transparency is only available for the Transparent Draw Styles.
How would you add transparency for lines? We can assure you that will never come.
[2014-09-30 16:35:37]
cmet - Posts: 552
I was hoping you could control the transparency of each Filled Draw study and not just one Global setting (in the event that you have more than one on a chart).
[2014-09-30 16:41:17]
But it would be nice if each study can have a transparency option, so users can select the level of transparency.
Transparency is inefficient and complicated and we have no plans for anything like this.
We will see about this.
