Date/Time: Fri, 18 Apr 2025 06:47:26 +0000
NFTY Remote Alert Comments
View Count: 59
[2025-03-24 19:46:12] |
User753526 - Posts: 57 |
I have just installed the NFTY application and it is working successfully. If I set an alert via the Alert Manager I can add a comment to the alert, when setting an alert to a Chart Drawing, is it possible for the system to send the Text attached to the drawing as a comment to NFTY? |
[2025-03-24 20:47:06] |
John - SC Support - Posts: 39353 |
There is no support for sending the text on a drawing as a comment to an alert.
