Date/Time: Fri, 18 Apr 2025 06:45:04 +0000
does enabling compression make a difference when data is compressed by default?
View Count: 69
[2025-03-24 19:20:14]
User753428 - Posts: 173
in sierra chart server settings, you can select "no compression" for "use real-time data compression."
but i noticed in the message log that even when "no compression" is selected, sierrachart compresses denali data by default so is selecting "standard compression" simply a case of compressing even more already-compressed data?
[2025-03-25 17:24:28]
Sierra_Chart Engineering - Posts: 19259
No this is not the case:
Compression cannot be disabled with some of the data feeds.
