Date/Time: Fri, 18 Apr 2025 06:47:27 +0000
BTC
View Count: 997
[2025-03-24 18:24:04] |
User642012 - Posts: 60 |
Hi which broker or exchange ca seirrechart supported for trade routing ? Thanks |
[2025-03-24 20:41:12] |
John - SC Support - Posts: 39353 |
What BTC do you want to trade? Is this Bitcoin futures? Bitcoin to USD? Something else?
[2025-03-24 23:26:12] |
Both futures and BTC USD Thanks |
[2025-03-25 14:15:45] |
For futures, we work with Interactive Brokers and most brokers that use CQG, Rithmic, or Teton for their order routing. For Bitcoin trading itself, the only broker we work with that offers this is Interactive Brokers - although you would need to check with them for certain on this. Refer to the following for more information: Supported Data and Trading Services For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
