Date/Time: Fri, 18 Apr 2025 06:45:04 +0000
Interpretation of Number Bars Cal values
View Count: 65
[2025-03-24 15:20:00] |
cmack1011 - Posts: 89 |
Can you please explain how a finish delta value can be larger than the Max/Min Delta value within the same bar/time period? For example, in this pic you can see that the negative finish delta is a larger number (more negative number) than the Min Delta (labeled as "Max Negative Delta") of the bar. Shouldn't the Max Neg (or pos) delta always be the largest neg (or pos) value during the designated time period? Thx
[2025-03-24 16:22:55] |
John - SC Support - Posts: 39353 |
Refer to the definitions for these items in the following section: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
